Issues with 2.34 GUI to work integral 2 FW 2.38.2.45 and reddish image when EDID switch set to something other than Custom [GUI]
-My setup: Panasonic DP-UB9000 > 3ft copper > Integral 2 > 3ft copper > Anthem MRX-720 > 3ft copper > 30ft copper > 3ft copper > JVC RS-4910U
-Current installed FW: 2.38.2.45. The installed Integral 2 FW when I opened the package and unlocked the Integral 2 was 2.40.2.45. I installed FW 2.38.2.45 because I couldn't get the 2.34 GUI from the FW 2.38.2.45 zip file to work with the Integral 2; thought maybe the GUI communication issue could be with the FW version.
-Integral 2 is unlocked
-30ft copper is active HDMI. All HDMI are certified premium HDMI cables, except the 30ft HDMI.
-I have tried putting the Integral 2 between the 30ft active HDMI cable and the projector. The image would flicker and drop in and out. I assume it was an issue active HDMI cable interacting with the integral 2, so I moved the Integral 2 between the Panasonic DP-UB9000 and Anthem MRX-720 and haven't had any issues.
My issues:
1. GUI issue: I'm unable to get the 2.34 GUI to communicate to the Integral 2. I've been able to change the Integral 2 MCU and FPGA to FW 2.38.2.45, so I don't think it is a USB driver issue. I didn't download FW 2.40.2.45 because my antivirus says there is a trojan virus in the zip file. Sorry, I didn't take a screenshot, but this was the file name it detected "Win32/Ymacco.AA32".
2. EDID issue: I haven't tested other 4k HDR/SDR/Dolby Vision movies, but on The Greatest Showman, when I set the EDID switch to automix mode, the image is reddish compared to setting the EDID switch to Custom [GUI]. The image is also reddish when I set the EDID to 4k60 420 8b SDR stereo. Also, when the EDID is set to Custom [GUI], the Panasonic DP-UB9000 is outputting HDR, but with the EDID switch to Automix mode or 4k60 420 8b SDR stereo, the Panasonic DP-UB9000 is outputting SDR. The Panasonic DP-UB9000 HDR/Color Gamut Output is set to output HDR BT.2020 (Auto). Because the image color is best on EDID Custom [GUI], I would like to use the GUI to tweak the Integral 2.
I'd appreciate any help getting the GUI to run and communicate with the Integral 2. Also, would like input on which EDID mode should I put the switch to for 4k HDR, 4k SDR, or Dolby Vision?
Erick
