1 - 1 of 1 Posts
As new in open package. Upgraded to the latest firmware and use for less than 1 day.
The HDfury4S is an updated version of the HDfury4 platform running the Scaler Firmware.
The HDfury4 platform is also capable of running the 3Dfury firmware, see here for the HDfury4 running the 3Dfury fw.
Owner of any HDfury4 (either HDfury4S or 3Dfury) can flash any firmware (Scaler or 3Dfury) at anytime.
HDfury4S is capable of connecting any HDMI sources to any Analog or Digital display. GUARANTEED!
HDfury4S offers all the features and controls you need to solve the seemingly simple matter of getting your digital AV sources to display correctly, easily and affordably on either an Analog or Digital display.
Whatever the HDMI source, HDfury4S is capable of scaling it up or down, deinterlacing it, and adjusting its aspect ratio to match the native resolution of your video display or computer monitor. Any display resolution up to 1920×1200 can be supported (or 1080p96).
If the input is 50Hz or 60Hz, you would be able to manually select either one on the output, perfect for customers who have USA TV’s in Europe or other way around(PAL/NTSC)
The HDfury4 Scaler is ideal for adding digital connectivity and scaling to existing Analog or Digital AV systems.
HDfury4S Key Features
  • Display HDMI content on ANY HDMI/DVI-D/RGB/VGA/YUV TV, Monitor or Projector
  • Always display any HDMI content at your display max resolution
  • HDfury4S can output in both Digital and Analog Video/Audio simultaneously !
    Therefor acting as an advanced digital/analog splitter.
  • Double, Triple, Quadruple frame 1080p24 material up to 1080p96
  • Double Frame 720p50 and 720p60 into 720p100 and 720p120
  • Transcoder and Scan converter, Toggle 50/60Hz or PAL/NTSC at will.
  • Any input can be up or down-scaled to a specified resolution up to 1080p96 for HDTV
  • Any input can be up or down-scaled to a specified resolution up to 1920×1200 for PC mode
  • 7.1 Dolby® True HD & DTS Master Audio
  • Input:
    HDMI 1.4 (HDCP compliant) input with 3D and Deep Colour support
  • Output
    : Digital HDMI / DVI-D and/or Component (YPbPr/YCbCr) and VGA (RGBHV) video output
  • 3 Aspect Ratio Modes (Full Width, Full Screen, Original, read FAQ for more details)
  • Custom porch settings, resolution and refresh rate adjustment through Windows Software.
  • Dynamically create EDID based on Sink EDID parameters
  • Customisation settings available through DIP SWITCH and buttons
  • Perfectly and automatically center image in all standard NTSC/PAL component modes
  • Manually adjust horizontal screen position in all NTSC/PAL RGBHV modes
  • Performs Colour Depth Upscaling in all modes (ON/OFF user selectable)
  • Horizontal and Vertical Sync Polarity Inverter included
  • Automatic SD/HD color-space selection
  • Accept third party accessories on its output
  • Improved output cable driver for driving long cable runs (40-50′)
  • Software/Firmware upgradeable through USB
  • Special software available for Mits RPTV and others 1080i display.
  • Sound output:
    • ■ Analog and Digital Optical (S/PDIF 5.1 Dolby/DTS) through an innovative 3.5mm combo jack and 7.1 DTS-MA & Dolby True HD via HDMI output
    • ■ HDMI audio passthrough
HDfury4S Input/Output mode:
  • VIDEO MODE INPUT COMPATIBILITY:
    • Basically any CEA / VESA input resolution is supported up to 1920x1200x60
    • All known SD, HD and Full HD formats are supported including:
    • ■ 480p50, 480p60
    • ■ 576p50, 576p60
    • ■ 720p50, 720p60
    • ■ 1080i25, 1080i30, 1080p24, 1080p25, 1080p30, 1080p50, 1080p60
  • VIDEO MODE OUTPUT COMPATIBILITY:
  • ■ 480p50, 480p60
  • ■ 576i, 576p25, 576p30
  • ■ 720p50, 720p60, 720p100, 720p120
  • ■ 1080i, 1080p24, 1080p25, 1080p30, 1080p48, 1080p50, 1080p60, 1080p72, 1080p75, 1080p96
  • All following PC graphics mode are supported in either 50 or 60Hz:
  • ■ 800×600, 1024×768, 1280×768, 1360×768, 1440×900, 1600×900, 1280×1024, 1400×1050, 1600×1200, 1920×1200
  • ■ Passthrough any resolution
1 - 1 of 1 Posts
