Yes right, but lot of back and forth, just cause oled miss lock information mainly, so that we are going to fix next week, should make it much easier.anyway, am i any closer to getting this thing resolved? sure seems like a lot of back and forth just to get the box to split a 4k signal? frankly tho, i could live with how it is opertaing now given that i can at least now use my projector with the 4ktv off, but given the price i would kind of like it to work fully, i.e. display the stats on the pj screen, give me accurate info on the oled, etc.
There is more likely something with the TCL TV, see my previous answer, see if you can try turning off CEC features and try the newer firmware link i posted and please confirm state of TCL TV when you took the picture.
I'll check your TCL usermanual later, yet i'm not sure it would help, your CEC test results would more likely be of more help and if no go, then we will buy same TV and check it.
So i cannot tell you right now how long we need to fix the issue fully, as it could be small settings on TV or something we must take care of via FW update.
