1 - 3 of 3 Posts
Hi there, this is my first post, so I apologize if this is in the wrong area.
I recently purchased a Vrroom and I cannot wait to receive it.
I was wondering how I should set it up, though.
My setup is currently an Xbox Series X connected to a Marantz SR55015 and then an LG Nanocell 85. The receiver is also split to my PC with a Razer Ripsaw HD (1080p) capture card. The capture card records gameplay and controls my ambient Hue lighting.
Where should I put the Vrroom in this setup for maximum efficiency? Should connect the Xbox to it, then the receiver and capture card? Or should do it from the receiver to the TV and capture card?
Thank you for your time.
We answered you via email.
But for others
xbox series x and other sources to the vrroom hdmi input
tx0 from vrroom to display
tx1 from vroom to razer ripsaw
hdmi audio port from vrroom to the marantz receiver.
1 - 3 of 3 Posts
