1 - 2 of 2 Posts
I just bought the HDHomerun Connect Quatro and it is my first adventure with HDHomerun hardware. I have an antenna with rotor and therefore need to be able to either run multiple auto scans without losing existing channels or manually enter channels. I also have a channel that looks great on multiple tv's with about 75% signal strength, but low or no signal quality so it doesn't get "found" with an auto scan.
Anyone know if manual programming is possible with this or any of the HDHomerun models?
If HDHomerun can't do it, are there any other recommended alternatives that can?
Larry
I haven't seen a way of manually adding in channels, at least not from the web GUI. If you're using the HDHomerun to stream to a DVR, then the DVR would store the tuning information. That's how I do it with MythTV and 2 antenna's. The HDHomerun for the most part just a streaming box onto the network, there really is no reason to scan channels on the HDHomerun if using some type of DVR that would do that instead.
1 - 2 of 2 Posts
