1 - 13 of 13 Posts
· Registered
· Registered
yup.
· Registered
yup. that pretty much sums it up in one word...
· Registered
while all of that is true, at 6 feet, it's overkill...
as an aside: check who owns tartan...
· Registered
Discussion Starter · #12 ·
Originally Posted by alk3997 /forum/post/19590200
Just remember to check that it is a "high speed" cable not a "standard speed" cable for 1080p (including 3D) output. Probably doesn't matter for 6 feet but never-the-less it is good to know the cable was certified for 1080p. "High speed" and "standard speed" are the only two types of speeds that are allowed by the HDMI Organization, despite some manufacturers putting 1.3 or 240Hz or 9 terrahertz on their packaging.
I did not see any of that info on BJC webpage.
do you think this cable would do the job?
BJC Series-F2 Belden Bonded-Pair HDMI Cable
http://www.bluejeanscable.com/store/...hdmi-cable.htm
· Registered
it definitely would, but it's overkill for the application at hand.
1 - 13 of 13 Posts
