1 - 3 of 3 Posts
I'm getting ready to install my new TV and Receiver and would like the forums input on should I ran a single HDMI cable from my receiver to Samsung 850 LCD or ran seperate HDMI cables from my DTV reciever and Blu-Ray to the LCD and use optical inputs for audio.
Just looking to get the best picture possible
Is this an AVR? I would run a single HDMI cable and let the receiver do all the work.
We need more information, in particular the make and model of the receiver.
So long as the receiver will pass the HDMI signal unmolested you should be fine. Going HDMI from AV component > receiver > display also allows you to access hi-definition audio codecs for Blu-ray components.
1 - 3 of 3 Posts
