Hi,
I have a Panasonic HD-ready TV connected to a Denon AVR-1611 receiver AMP. I have a Denon blu-ray connected to the AMP as well as DSTV HD Decoder and PC with an HD video card. The soures are all connected to the amp with HD cables, and the amp connected to the TV with a Lindy HDMI Extender unit (about 10m of cat6e cable)
My issue is that the blu-ray player and DSTV decoder work 100% but I get no image from the PC, no matter what I try, and what settings I use on the amp. If I connect the TV directly up to the PC with an HD cable then it works fine, and if I try connect the PC up to the HDMI Extender directly so that it is connected to TV through that then it still does not work, and as such assuming that it is the extender that is the problem. I also tried connecting my high end office laptop to the amp (also with HDMI cable) then I get the sound from the laptop through the HDMI cable, but no image on the TV.
Just seems odd that both PC's have an issue but the other sources work fine. Any suggestions on how to get this configuration to work?
Many thanks
Justin
Many thanks
Justin
