1 - 3 of 3 Posts
Hello,
I want to connect my pc with an NVIDIA Geforce GTS 450 with my Toshiba 40inch LED. My Pc is away from TV , around 50ft or 15m away. Should i go for hdmi over cat 6 or HDMI cable 50ft itself ??Help. I will be using 1080p full hd and dont need 3d or arc or whatsoever.
The cable which i selected is : http://www.amazon.in/dp/B004GW25WY
HDMI over cat 6
Convertor selected Rated for 100ft : http://r.ebay.com/HnKdih
Cable selected , Dlink Cat6 type : http://r.ebay.com/9w4Ss1
please help !!! :)
Will you be installing the cable in a wall or just along the floor? If installation is to be in-wall, I highly recommend using a 1" conduit for easy repair/replacing of cable(s).
You could use a Redmere cable for that length and still maintain the high speed HDMI specs.
CAT-6 with HDBT (HDBase-T) is another option but can be pricey.
HDMI cable - no passive cable over 8m is rated as High Speed, its simply not possible to pass the required test.
Active HDMI - as Otto says that is one option, though they don't work in all systems so always have a Plan B.
HDMI over Dual CAT Extender - avoid anything which is not externally powered (esp. with a PC as the Source) as there is a high probability of the extender not working in your system. Always look for a powered solution - http://www.octavainc.com/HDMI ethernet converters.html
HDMI over HDBT - utilises a single CAT6 and is very stable, http://www.octavainc.com/HDMI_extender_HD70STPEX.html
Joe
1 - 3 of 3 Posts
