Im looking for a new hdmi cable to connect my ps4 to my samsung plasma pn51f5300. Any suggestions? What cables are you using?
LIVE: AVSForum Tech Talk Podcast with Scott Wilkinson, Episode 5 Click here for details.
Enter to be our Home Theater of the Month Click here for details.
How about this one?Quote:
Originally Posted by AV_Integrated /t/1522717/hdmi-help-plasma-tv#post_24487760
It depends on the distance you need to go. If the TV is near your PS4, then these are nice at 6' or less:
6' Super Slim HDMI Cable
If you have a need for a 10 to 15 foot HDMI cable, then spend a bit more for the Redmere cables from Monoprice:
Redmere HDMI Cables
If running cables in-wall and it will be a tough run, then we should discuss it some more.
I recieve the mediabridge hdmi tomorrow. hdmi is all digital so it either works or it doesnt. Picture quality is all the same between expensive and cheap im assuming. Anyone ever test an expensive vs cheap hdmi and see a big quality difference?Quote:
Originally Posted by AV_Integrated /t/1522717/hdmi-help-plasma-tv#post_24491617
I'm sure that HDMI cable will work fine. The downside to it would be the size of the cable being so thick will be heavy on the connections and pull at the gear some. Still, by the reviews, it will work just fine.
Thank you. Im going to order one for my ps3. Its been using he same hdmi for 5 or so years now. Time to upgrade.Quote:
Originally Posted by trans_lux /t/1522717/hdmi-help-plasma-tv#post_24487819
Anytime we run into HDMI issues its almost always a cable issue.
We replace them with Perfect Path 1000 series and the issues go away-100% of the time.
The locking connector is a bit of a double edge sword-on one had its great as you have a connection that will never come loose
If you disconnect and connect often the locking nature can get a bit frustrating.
We have tried so many different cables over the years and nothing has come close to PPC.
http://www.perfectpath.com/products/ProductCatalog/tabid/869/CategoryID/2692/Default.aspx?c=High-Speed-HDMI%C2%AE-Cables-with-Locking-Connectors
Originally Posted by Otto Pylot /t/1522717/hdmi-help-plasma-tv#post_24491754
How much do they cost? I've used MediaBridge high speed hdmi cables in the past and they work just fine. I"m currently using Redmere cables because I needed the flexibility and the no strain on the connector end. I'd price a comparable MediaBridge/Monoprice/Blue Jeans cable and see. A lot of cables produced are more marketing hype than anything else. I'm sure the PPC's are fine cables but it all depends on what they're charging. There's an "M" brand of cable sold at BB that are really expensive but they don't perform any better than the ones I just mentioned.
It still works. Motion is a little blurry. Signal and sound cut out every now and then. Interference from plasma is also an issueQuote:
Originally Posted by Osirus23 /t/1522717/hdmi-help-plasma-tv#post_24493095
Why? Is the one you've had for 5 years no longer working?
Fuzzy picture sometimes only with the 5 yr old hdmiQuote:
Originally Posted by Otto Pylot /t/1522717/hdmi-help-plasma-tv#post_24493387
Interference from plasma is an issue?![]()
I dont know. I didnt graduate from the university of hdmi! I know 1s and 0s. Digital blah blah blah. You have something to say then just say it!Quote:
Originally Posted by Osirus23 /t/1522717/hdmi-help-plasma-tv#post_24493445
How does an HDMI cable induce a "fuzzy" image? I can understand data loss resulting in audio dropouts, but nothing that effects picture clarity.
Thats the thing. I tried another hdmi. No problem.Quote:
Originally Posted by AV_Integrated /t/1522717/hdmi-help-plasma-tv#post_24493791
A blurry image in a all digital connection is usually to blame on the resolution setting of the source. You will definitely want to check that the resolution of your source matches that of the display for best results.
It would certainly be somewhat unique if the HDMI cable is allowing the blurriness to manifest.
Originally Posted by Plasma5300 /t/1522717/hdmi-help-plasma-tv/0_20#post_24493831
