Hi all, not sure if this is the right pace for this, I'm new here... so go easy on me.
I have a problem. Bought a new apartment in NYC, and during renovations I had the contractor put a channel inside the wall so I could snake an HDMI and an Ethernet cable. After the walls were closed up and painted, I snaked the cable through, and that was all good.
The spot where the Verizon FiOS box enters the apartment is quite far from the living room TV location, so I got a 75-ft HDMI cable made by Kanex off Amazon. (I can't post a link yet because I'm new to the forum, but if you search for "HD75FTCL314" you'll see the cable.) I hid it behind the crown molding going around the room. (To be clear, I did test the cable between the FiOS box and the TV before running the cable to make sure it worked.)
Since moving in on Tuesday and starting to connect everything, there have been two occasions where the TV picture suddenly stops, and the screen says to "Turn on my STB or check my HDMI connections." The first couple times, it suddenly resolved itself after some period of time. Tonight, the picture died again, and I can't get it back.
This TV is a brand new Samsung 65" JS9500, a gorgeous 4K TV. It has the external OneConnect box, which has four HDMI inputs. The cable is plugged into HDMI1. I tried some steps to isolate the issue, but it only confused the picture...
I have a small 7" screen that I use when I do some mobile video work. It has an HDMI input. I took it to the OneConnect box, pulled the cable out of HDMI1, and plugged it into the tiny screen, and the picture came right up. So this made me think that it wasn't the cable.
But then, I disconnected my Chromecast from HDMI4 and plugged it into HDMI1, and the Chromecast picture came up immediately. So that tells me the port and OneConnect seem to be working.
Here are my possibilities I can come up with:
- The cable is bad and sometimes fails
- The TV/OneConnect box has some kind of issue TBD
- The cable, which has a built-in adjustable amplifier, is sending too much/little signal to the TV. I've tried changing the amplifier adjustment dial to all possible values (from 0 to 7) and no noticeable change. The cable came with no documentation to explain proper settings.
(As an aside, I also had a 50-ft version of the same cable that I was planning to run to the bedroom TV but haven't yet. I currently have that strung directly across the floor from the FiOS to the OneConnect's HDMI1 and it's working perfectly. At the moment.)
I'm planning to order a new 75-ft cable without an amplifier on it and try changing the cable, if I don't find any other solution.
To say I'm frustrated is to put it mildly. Any ideas/suggestions/prayers/incantations are welcome.
Thanks in advance!!
Mike
Thanks in advance!!
Mike
