Originally Posted by
adl /forum/post/0
What can I say I REALLY wanted to compare both!
I just got the cable so far I dont see any differences using my favorite HD file (Aviator) I wait tonight with total light control to see if I can see some differences!
I will keep you posted!
Please do us a favor to return the $40.00 HDMI cable. You can get the same one from Monoprice for $5.00 - $8.00. I just bought a bunch of 6ft cables for $4.99 each.
Why do need to return the $40.00 cables? Because purchases like yours feed on the frenzy and make more people to go out and have their wallet cleaned in the illusion of having a better PQ. Not to mentioned it is your money to the first place.
As far as differences are concerned, there is a theoritical difference between the component and the HDMI. If you use the component cables, we convert a digital signal from the source (DVD player for example) to analog signal to travel along the componenet cable. When the analog signal reaches your display (a HDTV monitor or a digital projector for example), it is converted back into a digital signal for display. The HDMI cable, on the other hand, transmit digial signal all along the path. There is no conversion.
In theory, all of the conversion is undesirable. In practice, your eyes (at least mine) would not be able to pick up the differences on the display device. So, if you want the psychologocal effects (like I do) you might want to use a HDMI cable.
.... but not a $40.00 cable.
