My set-up has just started giving my problems after a year of strong functionality and I am not sure what needs replacing to fix the issues.
Issue: HDMI signal from Tivo to TV is no longer found
Components:
TV: Samsung LNS4051D
Projector: Optoma HD65
HTPC: Radeon 4350
DVR: Tivo HD
HDMI switcher
Setup to TV: I have the Tivo and the HTPC on 3 ft HDMI to an automated HDMI switcher. The switcher then connects to the Samsung TV on a 15 ft. HDMI run.
Previously: This had run perfectly on all fronts.
Currently: The Samsung picks up the HDMI signal coming through the switcher perfectly, but does not pick up the Tivo signal anymore.
Troubleshooting tried: Hooking the Tivo to the Samsung straight to the 15 ft. HDMI run, works perfectly. However:
1) Trying different ports on switcher: No signal from Tivo
2) Trying different HDMI cables from Tivo to Switcher: No signal
3) Trying Tivo, through Switcher, to projector on a 15ft run, works fine.
Summary:
Tivo---3ft hdmi---switcher---15ft hdmi---tv = no signal
Tivo---15ft hdmi ---TV = signal
HTPC --3ft hdmi ---switcher---TV = signal
Tivo---3t hdmi---switcher---15ft hdmi---projector = signal
So basically, it all worked before, but now it is acting like there is insufficient signal strength to make the Tivo to TV connection through the switcher but I can't figure out where the signal loss is originating from as all the individual components and cables work in other setups.
Thoughts?
(P.S. This may not be right forum but wasn't sure where to post)
Components:
HTPC: Radeon 4350
DVR: Tivo HD
HDMI switcher
Summary:
Thoughts?
