I am having difficulty getting OTA HD reception. I am currently using a silver sensor antenna. I am getting nothing. I have the antenna plugged directly into my Zenith HD SAT520 tuner. Is there a sub menu that I could select to view locals.
I have been in contact with some locals in Jacksonville, FL and they state I should receive some locals with the silver sensor. I am contemplating getting a different antenna(outside). If I do this, how do I connect it. My setup includes...
1. AU2 directv dish with 3 lnb's.
2. 4 outputs for dish into a multiswitch (5x8).
3. 1 dual tuner directv/tivo receiver in 1 room.
4. 1 dual tuner directv/tivo rec. and hd tuner in another room.
So I have a total of 5 outputs from multiswitch into the 3 receivers. If i ahve an external anttena, would I run the cable through the multiswitch or directly into my hd tuner. Not sure how this works.
Chris
Chris
