I have just purchased a Toshiba SD-H400 and really love the TIVO feature as well as the DVD player. However, the HD bug has hit me. The only problem is the SD-H400 only has component outputs, not inputs. Therefore, if I upgrade from regular Comcast Digital Cable with to Digital Cable with HD and get an HD monitor, I don't think I will actually be viewing HD. The signal comes in through coax to the set top box, then I would have to use an S-Video cable to connect to the SD-H400 and then use the component outputs to the HD monitor. Will I be losing any hope of viewing an HD program in HD? Will the SD-H400 convert the signal to digital - live or recorded program prior to sending it to the HD monitor?
Thanks in advance!
Thanks in advance!
