I have been using an S-Video connection from my computer to my 32" television for a long time. It is a huge convenience to be able to post this message as I sit on the sofa. Unfortunately, even with a Geforce 2 running at 800 x 600, the quality isn't really suitable for reading text at a normal font from 12 feet away.
As i was shopping for a new TV the other day, I discovered that some televisions (monitors) actually had VGA connectors on the back for a direct connection to a graphics card. Cool!! I even discovered some that were XGA capable with all the HDTV capabilities (1080i, 720p, 480p, line doubling, and TV tuner) to boot!
The problem is that these sets are relatively hard to find, and the prices are fairly high as well. Also, web searches have yielded relatively few reviews or detailed information on these sets.
Which of the following HDTV Monitors (see the link below) have you seen, and which do you recommend?
http://www.tvinsite.com/twice/index....=searchResults
Princeton Graphic Systems, AR3.2, AR3.6 are two of my favorites at the moment. I saw Princeton's new 16:9 aspect TV at Definitive Audio and the HDTV display was definitely top notch, although a little small for my taste.
I look forward to your replies!
