Status
Not open for further replies.
1 - 7 of 7 Posts
OK I've looked for an anwer to this
how do you send your output from your HD set top box
to a second monitor which is my 17" LCD computer monitor with a VGA input?
Is this possible?
the distance between the 2 might be 50'
I just want to be able to see the same channel that is being broadcast
in my home theater simultaneously and it doesnt necessarily
have to be HDTV but that would be nice
I was thinking about a stand alone lcd monitor without a pc in the kitchenand I dont really want to buy another stb
what cables would work for this rg6? long vga?
I already have a component video amp
thanks
JJ
I once used a LCD Monitor as a TV and it worked ok, but don't fast forward any content and you will be fine, the LCD could not keep up with the signals being sent it when I fast forward a VHS tape, other then that, it worked fine.
Jim
Also, most LCDs can only do 1280x1024 resolution. Anything higher than that (e.g. HDTV) may display, but will alias. Depending on the unit, the aliasing can look pretty bad.
Gerald C
Discussion Starter · #6 ·
ok
I've heard a lot about that viewsonic tuner
will it work with a satellite tuner...I dont have cable
do you just use the vb50 for its connections?
and not its built in tuner
thanks guys!!
JJ
1 - 7 of 7 Posts
Status
