I have just started to play with HDTV on my Plus UP-1100. It is being fed by the HiPix card from my HTPC and I used an AccessDTV card for a few weeks before that. Same HDTV problem on both: I get a small horizontal line about 2/3 of the way up on the screen when the 16:9 projector output is chosen. When the regular 4:3 projector format is used, the horizontal "line" appears 1/3 of the way up the screen. Static or low motion HDTV images are beautiful in either screen formats with NO line. It is only on certain speed pans that the horizontal "line" (I think that it can best be described as "tearing") appears. It disappears when the motion stops.
Are you guys getting the same panning/motion artifact with HDTV feeds that I am getting? I have a VERY early Plus UP-1100 (#19900804)(have enjoyed it with my HTPC for 25 months now) and may have a very early version of the firmware. I need to decide whether to try a firmware upgrade to solve the HDTV problem or move to another, more HDTV capable projector. Comments would be appreciated!
