Status
Not open for further replies.
1 - 5 of 5 Posts
Perhaps I just easily missed this while looking around on the net, but I'm looking for a splitter for RGB source. I have found a DVI splitter, but have had no luck with RGB. I have found an RGB selector - but that's not what I'm looking for.
I'm trying to get the source signal to go from the hd box to the receiver and then split to the dlp and the projector so I can have the same source material showing on both at once.
I would think this would be a no brainer, but maybe I'm wrong.
Thanks in advance.
David
[edit] - I actually have a feeling this may need to be in the Integration section. I apologize if that is the case.
Discussion Starter · #5 ·
Multiple inputs would help greatly! Thank you.
Is there a good place to find all of these (splitters, amps, etc.) in one place online? Extron looked good, but you can't order directly from them.
David
[edit] actually, i'm really looking for a 3 input (might need to be 4), and a 4 output. that, i believe, would work best for the situation i'm in.
1 - 5 of 5 Posts
Status
