Status
Not open for further replies.
1 - 5 of 5 Posts
Help,
I have a Sony XBR Projection TV with only one input for HD and want to connect three (so far) sources. The problem is both that they use a different about of cable input
RBG hd+vd(5) and YPbPr(3) which I have to switch a mode on the TV for the different sources.
Panasonic RP-91 (YPbPr) 3
DTC-100 (RBG-Hd+Vd) 5
Xbox (YPbPr) 3 (no Confirmed)
Does anyone have any Idea's
Seeing as how 2 out of the 3 sources are Component and your TV will handle Component...then the best thing to do is buy a Transcoder that will change the RGB/VGA of the DTC100 into Component.
You can buy one of these Transcoders at www.audioauthority.com and I also believe that RCA sells one. They are less than $150.
Once all three sources are Component you can switch them using a Component switcher.
Do a search in this forum on "Component Switchers." There have been some recent posts from people who have discovered good units that are reasonably priced.
Lee
A Audio Authority transcoder is available in the classified section for $75. Also you can then purchase a Extron SW 2,4 or 6 AR on a web auction service. (Ebay, wink,wink). The total package less cables would be under $200.
RJW
Discussion Starter · #4 ·
The Converter you are talking about is a model 9A60 converter Correct?
also is there any quality differences?
Yes the 9A60 is the AA model. The RCA VHDC would work also. Price is probably the main difference between the two.
RJW
1 - 5 of 5 Posts
Status
