  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
HDTV tuner card support component output
984 Views 7 Replies 4 Participants Last post by  Flagg99
Which HDTV tuner card support QAM and component output so i can put hd cable box on it?
please help me.
Thank you
1 - 8 of 8 Posts
i guess no one knowa HDTV tuner that has component output or input.
There are none with component input. The best you'll be able to get is a card with S-video and most of them have that.
It's not the tuner card that would have the output, but the video card or MB (if integrated).
The mdp-130 does component, but you have to make a cable (db15 - component i think), and I believe they quit making them, and you have to use their pos interface.
You are better off using any capture card getting a newer nvidia card with the component dongle.
paul
ps and the mdp-130 remote sucks
out, but there are none that do component in.
is there anyway i can setup the cable box into tuner card so i can watch channel on Vista MCE?
The best bet I've found so far is to get an HD-SDI converter and a card with component capture.
AJA has the Xena series.
Decklink cards are cheaper however and I've come across a few people doing this. This is only for capturing video however, and audio would be separate, then sync'd after.
I actually posted a thread about this but seems most people aren't interested or are put off by the price (probably around 1500$... if I could get component capture working with an STB for approx 1000$ I'd go for it...).
I would also love to know if the Intensity Pro card is capable of capturing HD-Analog.
1 - 8 of 8 Posts
