Status
Not open for further replies.
1 - 3 of 3 Posts
This is probably a bit of a longshot, but I would like to find out if there is a display (pref. direct-view) that can display both ATSC/NTSC resolutions AND accept PAL 50Hz (or 100Hz, better yet) inputs as well? Or would a 50 or 100Hz PAL input "just work" on a set capable of accepting lots of different sync modes like an HDTV can?
I think that the Sampo HD models sold in the US will display PAL, albeit at 50 Hz non-line doubled rates.
If you're looking for a standard definition set that will display progressive scan NTSC and 100 Hz PAL, such sets appear to be common in Europe, but haven't made it to North America. If you wanted one badly enough, it would probably be possible to import such a set, but I imagine that would be hugely costly for a large (greater than 30") set.
1 - 3 of 3 Posts
Status
