Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
I have a data600 and i have questions. what does HDTV mean? can i switch it on or off on the board? Cause, on the right of the projector, there are six LED's (two rows of three yellow lights, one green and red). sometimes, the ledon the left of the upper row is snapping while the red leds snaps to...what does this mean? above the left yellow led stand HDTV, so, what is my problem?
i thank you for helping
· Registered
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
This is a question for the Display section of AVS. Please list the brand, model, type (LCD, DLP, CRT, etc.) & price (over $5000 or under $5000) so I can move it to the proper forum.
HDTV is a new digital TV format that is different than the current standard TV system. Even though your projector has an HDTV light, you will not get HDTV unless you have an external HDTV receiver for satellite and/or local DTV reception.
· Registered
Discussion Starter · #3 ·
well i have a CRT projector from barco, data 600
i don't want to sell it, i just had the question. i wander, if i don't get HDTV, why is the red light then snapping on and off?
thanks!
1 - 3 of 3 Posts
Status
