Status
Not open for further replies.
1 - 3 of 3 Posts
I have just started the planning of a hush box for my Seleco HT200. It is a relatively quiet PJ, but I would like to have complete silence (or as close to it I can get).
Now, in order for the HT200 not to run to hot, I need to change the air in the hushbox. But how often?
Is there a formula that states (given the wattage rating of the lamp and the internal volume of the hushbox) how often the air in the box has to be changed?
There was a discussion in this forum about hushboxes and
how much airflow was needed some time back - including a
formula for how to calculate it.
For starters, I remember the value for the JVC G15 which
has a 400+ W bulb and dissipates about 650 W. A G15 in a
hushbox requires about 20 cfm of air flow.
Since a Seleco dissipates less heat - you can ratio the
20 cfm figure down by the ratio of the Seleco heat
production to that of a G15.
Greg
1 - 3 of 3 Posts
Status
