Can anyone confirm that this power supply will fit into this case?
SeaSonic SS-300TFX Bronze 300W TFX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151090
hec Black 0.7mm Thickness SECC Steel 7K09BBA30FNRX Micro ATX Media Center 300W Power Supply / HTPC Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121100
Some of the newegg reviews mention having to modify the case to make it fit.
I don't need a replacement PSU right now, but the stock one doesn't have the best reputation so I would like to have a spare just in case and this unit has pretty good reviews.
