1 - 9 of 9 Posts
Dear All,
I would like to know the best setup for my Onkyo 809 with my JAMO D600 to achieve the best sound quality?
Please advice on the setup, as I would like to setup ASAP to checkout the quality of the speakers.
Thanks a lot
Awaiting for kind feedback
Hossam
I am afraid I do not know what to tell you. Are you asking how to connect things? Are you asking where to put your speakers? Are you asking how configure/program the Onkyo?
Discussion Starter · #7 ·
Configure with my speakers?
With THX everything? I'd try THX modes. You should still run the auto calibration. I think your manual instructs you to set it to 4 ohm mode for 4 ohm speakers. Onkyo's run hot, so I'd probably set it to the 4 ohm option if one is available.
1 - 9 of 9 Posts
