Hi all,
My parents purchased a new home that was just finished by the builder. The electrician ran a single RG59 to the location above the fireplace in the great room. I really want to put the HD cable box in the basement.
The problem is that the walls are closed up. The builder has offered to route a cable outside/under the siding and into the basement. I guess that'll have to work.
The run is 80', so I'm wondering if I should buy a 100' length of HDMI from Mono, or run two CAT5e cables and use a balun.
Thoughts? Suggestions? Please.
Shane
Shane
