Status
Not open for further replies.
1 - 4 of 4 Posts
Harvey,
you need to get Powerstrip, latest version I think is 2.29 at
www.entechtaiwan.com
Good luck!
Christoph
Actually, the latest version is 3.30. I'm sure you meant to write 3.29 though and not 2.29. :)
Also do searches here on powerstrip and custom timing, you might need to tweak a bit to get your projector to accept native pixel perfect 1280x720. Some of them refuse to do it under any circumstances, unfortunately.
Banned
You know, there is an entire forum dedicated to connecting your computer to your projector! You may find a higher response rate than in just one forum. Or, did you also post over there already?
1 - 4 of 4 Posts
Status
