Status
Not open for further replies.
1 - 4 of 4 Posts
I need help and suggestions or parts.
I have a 1292, very low hours and it could power up in the seller's place. But the green tube had some half coolant. There were no contamination in the interior, so we thought to top it up by ourselves.
We bought a pint of gylcol, topped it up after dismantling the tube. It is an easy install.
After that we tried to power up and it did and shut down immediately. It is so brief that we could not see the error code.
We checked everywhere in the green tube and the neck board. Looks OK.
Can you guys suggest something for us to check and identify the problem?
CH Yeow
Discussion Starter · #3 ·
Originally posted by Drew Eckhardt
The 1292 will not power up if the ground? connectors to the lenses are not installed.
Thanks Drew,
I will check it out. Any one who can offer more suggestions?
CH Yeow
A bent pin on the neck board will trigger the shut down. Be sure none are bent over. Also check that all the grounds are in place as Drew mentioned.
1 - 4 of 4 Posts
Status
