1 - 4 of 4 Posts
Hi All,
I am desperate need of help. I have a 50' Philips Ambilight and I am in Red distortion hell!! Everthing that should be black (even shaded areas) is all of a sudden covered in red pixels/noise/distortion. This just happened the screen flickered for a sec and then came back all messed up. It almost looks like looks like a picture negative except in red. Any have any ideas what this is. I called a repair guy but would really like everyone's input.
Can be very difficult to diagnose, many possibilities from a simple voltage adjustment to bad board(s) to bad panel. If a voltage adjustment does not work, then start trying boards. If boards can't fix, then replace the panel. Post full model number of Tv.
There have been several threads on what may be a similar problem. Try a search for 'sparkles', or 'red dots'.
1 - 4 of 4 Posts
