Status
Not open for further replies.
1 - 1 of 1 Posts
Hi:
I just bought a MDP-120 to use as the core of a HD PVR HTPC.
My current plan is to take the components out of my HP 8770C (850MHz Athlon) and put them into an HTPC case.
I beleive my computer uses and Asus K7M motherboard with PC100 memory. Will these components work in a newer MicroATX motherboard?
I see 3 choices:
1. Migrate my existing components to a new case (and motherboard)
2. Build from scratch
3. buy a new computer in the $600 range.
#2 seems to be pretty expensive compared to 1 & 3. I don't want to use my existing PC as-is because it is very loud.
Any suggestions would be welcome. Looking for minimum outlay to adequately support the MyHD board.
1 - 1 of 1 Posts
Status
