Help a newbie with system design
521 Views 6 Replies 3 Participants Last post by  jbock
Hi all,
Wow.... What a great site. I've been lurking for a while. Searching and learning. However, as you all know, the more you learn the more confusing things become. Every night for two weeks I've been researching tirelessly, finally going to bed with blood shot eyes and a headache you wouldn't believe. Now my wife wants her husband back. She is now giving me awful ultimatums. Please help.
I'm designing a HT for our home office. Approx 10'x12'. Due to space limitations I'm basing my set up around the Panny ED TH-37PWD7UY (the commercial one). I am open to other suggestions. I'll be watching SD through Dish, DVD's and PS2.
I have $1500-$2000 for:
1. DVD player
2. Receiver
3. Compact 5.1 speaker set up (Paradigm Cinema 110 CT looks good)
Or I need a really nice HTIB.
Also could you tell me what cables to buy and the best way to connect everything. I would like also to connect my PC (with nvidia 6800 graphics card) to the panny for occasional use.
Can you tell me how to spend my money, and how you would connect everything.
TIA. Scott.
See less See more
Status
Not open for further replies.
1 - 7 of 7 Posts
All I can tell you is what I have done for our living room. I got the Panny 42" ED 7UY and a Onkyo 6.1 HTIB. I just recently purchased the Sony 775 DVD player and I use dish network standard sat.
The DVD player I Use Component straight through to the Panny and optical audio to my receiver.
I use S-video for my Dish while it's not the best anymore would be a waste since it's standard sat anways.
I plan on getting an Xbox soon and will hook it up into the VGA port on the plasma. To this you need to get the component cables for the ps2 or xbox and then buy some female connectors which are really cheap. Then all you need is a vga to component cable and your in business without having to buy another input insert for your plasma and I don't think the 37" has an extra slot anyways.
In all I would say i spent about $3400 on the TV,DVD player and HTIB and cables. I ran Monster cables for speakers.
But the dvd/HTIB was only $800 estimated so you should have more than enough to get yourself a pretty sweet setup. While mines not the cream of the crop it's more than satisfied me for now.
Well that's until I can get a house with a basement and really go nuts. It never ends:)
See less See more
Don't forget to budget for shipping/delivery?, Extended Warranty, Calibration DVD or ISF, and possibly a wall mount and a/v rack/stand...
Also consider a decent upscale DVI/HDMI DVD player if you plan to watch a lot of DVD's...
I use DVI to connect for DVD player, Component Video for cable box, 2 way splitter/ coax direct to TV input ( for low band analog basic cable), I run all audio outputs thru a Yamaha receiver (Optical for DVD, RCA for cable box...I also connect my cable box's audio output to my TV's audio input so I don't always have to watch TV thru the HT...
Thanks guys, I've read that using an upscaling dvd player is not necessary with an ED plasma, am I correct?
No it is not necessary..but you'll get many differing opinions as to weather an upscale DVD player will improve PQ on your ED plasma...In my case, my older pro scan looked crappy on my ED plasma...A upscale player hooked up thru DVI made a huge difference in improved PQ...especially when calibrated with AVIA DVD calibration disk...
I wonder if it is the all-digital (DVI) connection that made difference. Have you tried using a component connection on your upscale dvd player to see if you get a different quality picture? I would be interested to see if there really is a difference.
I have tried and do get a better PQ thru DVI than component...but I can't be sure it's soley due to the all digital connection because my player (Denon 1910) only upscales 720 & 1080 via the DVI connection...so the player is basically just another pro scan when hooked up via component..
1 - 7 of 7 Posts
Status
