1 - 6 of 6 Posts
Banned
If they were high end 4 ohm speakers then yes buy a amplifier that can power 4ohm speakers? For a HTIB that cost £121? Not
worth it.
Some of my speakers are 4ohm...but not low end stuff
Banned
Originally Posted by mcbretttetettet  /t/1525413/help-a-newbie#post_24557719
Hello all,
So I recently got these speakers from a family member:
http://www.overstock.com/Electronics/Acoustic-Research-PL100-5.1-Home-Theater-System/3344683/product.html
I know they're old but you can't beat free.
What I want to do is hook up my PS4 and Sony Bravia KDL40 to these.
I figured I need a receiver but I don't know much more than that.
Here's something that is in the same price range as the street price of the speakers and will work pretty well:
http://www.accessories4less.com/make-a-store/item/denavr1513/denon-avr-1513-5.1ch-home-theater-receiver-3d-ready/1.html
Discussion Starter · #5 ·
Thanks for the advice everybody. I honestly don't think these were used prior to my acquisition. I'm definitely not looking to spend a lot and the denon looks good for what I'm trying to do. The ohms were something that concerned me, from my experience with guitar gear I always heard mismatched ohms led to damaged gear. Would I damage the speakers or the receiver? I don't turn up too much but would it be so quiet that it's not worth bothering?
1 - 6 of 6 Posts
