Status
Not open for further replies.
1 - 5 of 5 Posts
Hi all,
Im in the market for a new tv prolly not going for hd.Had some car Problems now budget has changed
I need recomendations for a nice 27'flat, but dont want to spend more than say $325.00 (us).
My question is , i hav a pvr from CONcast with the componet outs if i get a tv with 2/ component in's can i use them: 1, for my dvd 2, cable box and get better pict from cable than using s-video?
Thanx
Originally Posted by mrreality13
Hi all,
Thanx
Sorry to hear about your situation. I seen some Toshiba. Panasonic. & Samsung 27inch models for under 300.00. Try pricegrabbers.com.. Search the net. Ebay. It might take some time, but you will find a good 27inch flat screen for that price.. Components are always better then Svideo.. You'll get the best posible 480i picture using components. Don't know about the cable box since I don't have cable. GL.
Premium Member
You need to use a more descriptive subject line.
1 - 5 of 5 Posts
Status
