Good afternoon all,
A few months ago I bought a BIC F-12 for my 600 sq. ft. open living room which, while was better than my home theater in a box sub, left the lady friend and I wanting more "rumble" in our chests. In order to fill this craving I am looking into building a subwoofer using an old Eclipse SW8122DVC subwoofer I have had sitting around since 2006. Using BassBox 6 Pro I have made some boxes, but to tell you guys the the truth I'm just lost on how powerful this thing will be based on what I am seeing.
Also, I don't know what kind of amp I need to buy to power this thing to it's potential. The Dayton audio 500/1000w amps I see on Parts-Express are within my budget but I have a few issues. BassBox shows the speaker bottoming out at around 10hz with 500w of power, but if I move the power loads to 273w (8 ohm load on this speaker) I no longer have to worry about bottoming the driver out. Can I run the speaker at 500w and the 24db/octive cutoff save the speaker from bottoming out? How does that cutoff work?
Now for the limitations. I plan on building this box as a table that will be behind the couch so I can throw all those darn pillows she has to buy on something else besides the floor. I am looking for dimensions around 22in H x 45in W x 15in D so that I can put 4in legs on it and a top that is 6in off the ported enclosure. I would like to keep my price for an amp under $350. Lastly, I would like to keep the design of the box as simple as possible because I don't have the knowledge to make a multi angled design.
Thanks for your help
