Status
Not open for further replies.
1 - 3 of 3 Posts
Hi all, i just can't seem to access the factory and the service menus on my Z1.
I read a thread here that was saying about tweaking the service or factorey menu to improve the image etc and i want to have a play with it. They say to hold down input + select for 5 - 10 seconds, but i get nothing. Mine is a New Zealand model, but they all have the same model numbers so i doubt there is much change there. Do i have to have a signal going into it at the time? Any specific thing that has to be on/off for it to be accessed?
Also if people could post links to tweaks etc that would be GREAT!!
Cheers
Are you holding down the buttons that are directly on the PJ (that is, not the remote control)? Its a little tricky in that you have to press both at exactly the same time and hold for 5 seconds.
Discussion Starter · #3 ·
Yeah after i read someone elses post about it being tricky i tried a few times in a row and got it right.
Be keen to see other peoples setups and configs though.
1 - 3 of 3 Posts
Status
