My basement has already been finished into a 'regular' room. I am converting it to a HT and one of the first steps will be mounting my projector so I can determine screen size. I need an outlet on the ceiling next to the projector of course. What would be the best way to tie onto another wall outlet? I have thought of cutting a sizable hole in the ceiling between the projector and wall and fishing the wire through that way and then patching the hole. I'm assuming I need to get access to the top plate of the basement wall to drill holes for the wiring. Am I missing something obvious or an easier method? My video/audio cables will need to come down the same wall as well.
Any advice appreciated.
The beginning.
http://www.avsforum.com/avs-vb/showthread.php?t=791905
The beginning.
