Hi all,
I am located in Australia and as such have the Panasonic AE300. I recently purchased a Panasonic QTR2140 1080i HD set top box and found that there was a small black boarder all around the screen edge when setting the HDSTB outputs to HD and inputting the STB's output into the Projector by Component or VGA. I was frankly a bit unhappy about this as I was under the impression that the Panasonic AE300/L300U downscaled 1080 perfectly by 2:1 so I did not expect to see a boarder and even if this was not the case, I would have thought that the projector would have scaled the HD input to fill the screen. I have contacted Panasonic Australia and they agree that this is not right and have gone into 'testing' until further notice.
I have tested the STB on two AE300's and a CRT TV and have tested two of the STB's. The STB was fullscreen via component onthe CRT TV.
Do you know why the boarder is present? Is this a limitation of the design of this projector? I have friends with the same STB coupled with HS10's and they get full screen, I have also seen CRT HD TV's with my HD STB and they display full screen also. Is there or was there a thread on here about this limitation of the AE300/L300U ? What are other peoples experiences?
Cheers,
Nick
Cheers,
Nick
