1 - 2 of 2 Posts
· Registered
Is it possible to run 4 speakers off of 1 volume control? The volume control has 4 wires going to it and I would have 8 wires coming out going to 4 speakers.
I assume Id need 8ohm speakers and running them like this would drop them down to 4ohm which should be ok?
What about the other speakers that aren't ran like this, would those need to be 4ohm speakers or is it ok if they are 8ohm? These other speakers would have 2 speakers per room/per volume control.
· Registered
You can, but you will want to get an impedance matching volume control. Even though you think it will only be 4 ohms, speakers fluctuate and will drop down to 2 or even 1 ohm without impedance matching.
1 - 2 of 2 Posts
