1 - 7 of 7 Posts
i have a barco 708mm manufactured in 1999,it is strange the green tube is stable but the blue and red tube picture keep shifting right,what's wrong with this machine
Most likely it's the focus/H shift board. Email me if you need one. I've got spares.
Don't Forget that all 4 toe in nuts/ bolts must be tight or the tubes will move as the PJ heats up.
Seen it happen a lot.
Roland
Discussion Starter · #5 ·
Thank you B4 ,the 4 toe in nuts is tight.the blue and red tube shift the same direction while the green one is rather stable.if it is as what curtpalme said then all 3 pictures would shift the same way.is is realy something wrong with it's the focus/H shift board??
1 - 7 of 7 Posts
