1 - 2 of 2 Posts
Discussion Starter #1
Hello I got a samsung un46fh6030fxza 3d led tv and I am trying to play the BD50 avc 3d iso file using powerdvd 19 to watch it in 3d but the only way I can view it is in anaglyph 3d. If I downlaod 3d sbs or 3d ou and then try to watch it on the tv then it works fine if I change the 3d option on the tv to sbs or ou. computer specs:
processor: i7 7700hQ
gpu: nvidia gtx 1060
ram: 32gb
I have tried looking at several different things and everything is outdated, so I would really appreciate it if someone could really help me out.
There is a patch called BRING BACK 3D VISION for NVIDIA GPUs. Get that, patch the latest compatible driver.
Then use MADVR with that driver via MPC-BE (enable MVC playback in the settings for MPC-BE) to play the ISO files. Left click, open with MPC-BE, it will boot into 3D mode and play your films. No menus, just the film which is what I prefer.
You'll have to do a bit of goggling to get it working but this is the best way imo.
1 - 2 of 2 Posts
