First post, but been a longtime lurker. Finally need to get some advice to figured I should join
I need some help as I am debating between a Elemental Design A2-300, a Epik Sentinel, and a SVS PC-12NSD. The Sentinel is discontinued so finding info on it has been a little bit hard. All these subs are used and within my price range.
I was wondering what sub of those three you would recommend and why?
This would be used mostly for HT purposes.
