1 - 4 of 4 Posts
Need some input on a build.
Looking to be able to do 1080p MKV's.
Will be hooked to my Panny 50" S2 via HDMI
I do have some parts I could piece together but they are a bit older, not sure if it will do what I want. Can someone please give some input
AMD Athlon64 x2 5200 CPU (dual 2.6ghz)
ASUS A8N-SLI Mobo
4gb PC3200 RAM (mobo only supports 3200)
Don't have a video card, so I'm open to suggestions. Was looking at a GTX430
Also, need to know what software suite would be best suited for the MKV playback. Should I just use Media Center in Win7?
Would also like to be able to do Hulu/Netflix on it as well.
With this old junker be able to do it you think?
1 - 4 of 4 Posts
