I've looked around quite a bit for some basic guidance on how to start building a quality audio system. I'd like some general insight on some of the following:
Guidlines on how to allocate my budget. I've come across various theories in the past, but I haven't found anything comprehensive in the past week of looking.
What is the story with integrated amps versus receivers? From what I understand, to achieve high quality one cannot use a receiver. Why is this? What are the fundamental differences between amps and receivers? My understanding is that receivers are capable of doing what amps do (amplify a signal) along with receiving AM/FM and switching video components? Is there something more to it?
I am also under the impression that there are not any amps/receivers that are truly good for two channel listening but are also capable of processing 5.1 sound. Is this more or less true?
How do I construct a system that does stereo very well but can be modified to handle 5.1 sound in the future?
If I were to go about the process by gradually incorporating audiophile grade components into an existing system, where is the best place to start? I have been planning to start by replacing my vintage Rectilinear monitors but perhaps there is a better approach. After that, my next step would be to replace my Pioneer Dolby Pro Logic A/V receiver with an integrated amp or a modern receiver.
I would like to use bookshelf monitors for my mains. Where can I look for a good list of obvious candidates? So far I've been considering the Sonus Faber Concertinos, the Kef XQ1's, and the Dynaudio Focus 140's. I'm not sure if this is a good cross-section to choose from or just scratching the surface. My present listening environment is pretty spacious, but I plan to have my speakers a lot longer than I stay in my apartment. I'd be willing to spend up to $2000/pair for new speakers or ...
I'm strongly considering going with used speakers to get more bang for my buck. Is it a mistake to purchase used speakers and forfeit the right to audition them in my home (along with taking on the risk of buying used equipment from an unkown)?
I understand that most of these questions are probably opening up a can of worms that requries more than a brief summary to address, but I would very much welcome any and all discussion of (and outside resources dealing with) conventional wisdom and contrarian viewpoints.
