1 - 2 of 2 Posts
My setup is as follows:
42inch 1080i plasma
ps3
xbox360
ED a2-300 subwoofer
The room that it is used in is relatively small, but I may potentially move it to a larger room so I dont want to be stuck finding one for a small room and then move, I'd rather have too much power in a small room...I think i'm gonna skip on the hdmi and buy an older model and just use optical since I would have to use that anyway with most entry level hdmi receivers...what models should i be looking at for around $200 to get the most for my money?
I dont know much on the Pioneer but you can look at the HK at Harman Audio at Ebay and onkyo and marantz at accessories4less and shoponkyo. It seems that these brands have their issues so read up on them but overall, these are great brands.
1 - 2 of 2 Posts
