Hi guys, i have a samsung tv model UN46EH6030, and always used it with my gtx 660ti card. this week solving a youtube problem i noticed a setting called Dinamic interval, and there is 0-255 and 16-235. i selected 0-255 setting and did this test http://www.lagom.nl/lcd-test/black.php
o noticed that i just can see after the nuber 25 square. i am using my tv in pc mode, and there is a setting called hdmi black level that was set to low, when i put to normal i notice a little washed out image but i can clearly see every square on the same test.
when i set to 16-235 again with black levels normal the image is all washed out with blacks on the page now being grey, but when i set back to low blacks that was my initial setting i start seeing the squares after number 8. so what should be the best setting?
1)full rgb+normal black=bit washed out but pass on test
2)limited rgb+low black=very good contrast but do not pass on test (just see the square after number 8)
btw i am using through hdmi directly to my tv from gtx 660ti.
thanks in advance.
thanks in advance.
