Status
Not open for further replies.
1 - 3 of 3 Posts
I have a diplexer mixing my cable and satellite signals outside the house and another diplexer separating he signals inside. Worls fine.
Now I need to add to the mix the signal from my OTA Antenna (for HDTV ATSC reception).
Is there such a thing as a "triplexer" ?
Can anybody think of a way to mix the signals? (No more holes in the walls, no more cables allowed in my house)
Nope, the cable and OTA signals use the same frequencies, you need a new cable for the antenna...
Satellite is at a much higher frequency range so it can be mixed with one of the others fine. But OTA (VHF/UHF) is the exact same frequency range as cable TV - so you can't mix those it would cause terrible interference. I get such interference just from small signal leakage from a strong local UHF channel 15 - it causes herringbones on cable channels 65-66 which is at the same frequency as OTA channel 15.
1 - 3 of 3 Posts
Status
