Status
Not open for further replies.
1 - 3 of 3 Posts
Strange problem: on my Dish 5000 receiver, when I tune to one of the HD channels (whether entering it directly or using the guide), I can no longer directly enter a channel number to get back to another channel (HD or otherwise). I can use channel up/down -- but can't enter a 3 or 4 digit channel no. to directly access another channel. If I use the guide to go to a non-HD channel, I can then directly enter a channel -- whether 3 or 4 digit, std or HD.
It seems to be related to the message that the 5000 displays on the std. definition screen: "Attention: To watch this DTV program, switch the TV to its DTV tuner input per the TV owner's manual." It's like this banner is blocking the input of the digits or something (but again, channel up/down works fine).
Help! This is screwing up my ability to program direct-access favorite channels into my learning remote.
Is anyone else experiencing this? Do you know how to fix it?
Menu-1-9430
or
Guide-9430
where 9430 is the channel you want (Showtime-HD in this case.)
Abdul
Philips 60PP9601, join the Philips_HDTV discussion group
DirecTV + Sony SVR-2000 TiVo upgraded to 128 hours basic quality
Dish 5000 + HDTV Modulator
HTPC: Duron 750, K7 Master, Radeon LE, AccessDTV, Cybermail, Audiophile
Kenwood VR-407 receiver & subwoofer, nOrh 4.0 marble center speaker
s>
Good call, Abdul! But, actually
Menu-1-9430-Select
or
Guide-9430-Select
You may need to add a second Select command. (I'm not sure whether this is only necessary for 3 digit channels.)
Peter
1 - 3 of 3 Posts
Status
