Status
Not open for further replies.
1 - 2 of 2 Posts
Just bought the B&W. Hooked up my Philips Q50 dvd player to Nak avr 10 via digital coaixial cable. Running two bmw 602.5 mains and b&w lcr 600 cc. et solid sound from the mains but very very low sound from lcr 600 cc.
Played around with all settings including the center channel level setting on nak, even when turned up to 10db it is still very low.
I think the center channel amp function on my nak is blown. Just realize that my previous center did not sound that good because it might be the amp and not the speaker.
Any ideas? All speakers are bi-wired.
make sure that you have the Jumpers out of the speakers. or go into there set up menu of the receiver and see if it is set to yes. some dvd players have settings in the menu to set the size of the speakers give that a try.
have a good one.
1 - 2 of 2 Posts
Status
