Help! Can't get PC to display properly on my HDTV.
1365 Views 5 Replies 3 Participants Last post by  cganesh75
Hello,
I am new to all of this. Yesterday I went out and purchased a Gateway GM5664 . The specs of this PC are:
AMD Phenom™ 9600 Processor (AMD Live!™) (2.30GHz, 2MB L3 cache, 3600MHz system bus)
Genuine Windows Vista® Home Premium (32-bit)
3072MB 667MHz dual-channel DDR2 SDRAM (2-1024MB modules & 2-512MB modules)
1000GB 7200rpm Serial ATA II/300 hard drive w/ 16MB cache (2-500GB hard drives)1
Hybrid Blu-ray/HD DVD player and SuperMulti DVD-RW DL drive (Windows Vista® only)
Premium system design with carbon fiber faceplate
ATI Radeon™ HD 2400XT 256MB discrete video memory with Dual-DVI, S-Video and HDMI supported
Gateway® 15-in-1 media card reader with copy button and IR receiver
Gateway® USB 2.0 speakers
Analog/digital TV tuner
I am running this through a DVI to HDMI converter on my 46" Sony KDF-46E2000 (Which the native resolution is 720p, 1280x720) via the Sony's HDMI port; and I set up the PC so that it's set 1280x720 however, the PC's video signal does not fill the entire sceen properly. It's displayed in widescreen, but there is about 1/2 inch shaved off the bottom, top and sides of the screen.
Can anyone help me out, just want the PC to fill up the whole screen, thanks!
See less See more
1 - 6 of 6 Posts
Mabe not since your HDTV is emulating a standard CRT TV by overscanning all of its input over HDMI/DVI. If the TV also has a VGA interface then it may not overscan that input since that is is trying to emulate a PC monitor instead of a CRT TV.
You may be able to use an application called PowerStrip to downscale(shrink) the output from your PC video so that when the
TV overscans it back up it has the appearance of 1:1 Pixel mapping, however, small font text in PC dekstop appliation will be blurry since the TV has to invent the content of the missing text pixel deleatd by the underscaning the PC output.
Here are the specs of the TV:
http://reviews.cnet.com/projection-t...html?tag=specs
Product Type
46 in Rear projection TV
Series
GRAND WEGA
Digital Television Certification
HDTV
Video Interface
HDMI, S-Video, Component, Composite
Width
43.3 in
Depth
15 in
Height
30.2 in
Weight
59.5 lbs
Display
Diagonal Size
46 in - Widescreen
Technology
Projection
Projection Display Technology
LCD
Resolution
1280 x 720
Display Format
720p
Image Aspect Ratio
16:9
Progressive Scan
Progressive scanning (line doubling)
Viewing Angle
130 degrees
Viewing Angle (Vertical)
60 degrees
Comb Filter
3D-Y/C digital
V-Chip Control
Yes
Color Temperature Control
Yes
Picture Adjustment
Vivid/Standard/Custom
Additional Features
Channel labeling, Digital reality creation multifunction, WEGA Engine Picture enhancement technology
DVR
DVR
None
DVD
Type
None
TV Tuner
Analog TV Tuner
NTSC
Video Features
HDTV Ready
Yes
Input Video Formats
480i, 480p, 720p, 1080i
Freeze Memo
Yes
Parental Channel Lock
Yes
Closed Caption Capability
Yes
Radio
Radio
None
Remote Control
Remote Control
Universal remote control - Infrared
Supported Devices
TV, VCR, Cable box, DVD player, Satellite TV system
Features
Multi-brand compatibility
Remote Control (2nd)
Type
None
Audio System
Sound Output Mode
Stereo
Audio Controls
Bass, Treble, Balance
Speakers Included
2 speakers
Output Power / Total
24 Watt
Additional Features
SteadySound auto volume
Speaker(s)
2 x Right/left channel speaker - Built-in - 12 Watt
Connections
Connector Type
2 x HDMI ( 19 pin HDMI Type A ) - Rear, 4 x Audio line-in ( RCA phono x 2 ) - Rear, 2 x Component video input ( RCA phono x 3 ) - Rear, 1 x Component video input ( RCA phono x 3 ) - Side, 1 x S-Video input ( 4 pin mini-DIN ) - Rear, 2 x Composite video input ( RCA phono ) - Rear, 1 x Composite video input ( RCA phono ) - Side, 1 x Audio line-in ( RCA phono x 2 ) - Side, 1 x Digital audio output (optical) ( TOSLINK ) - Rear, 1 x Headphones ( Mini-phone stereo 3.5 mm ) - Front, 1 x Fixed/variable audio output - Rear, 2 x RF input ( F connector ) - Rear
Just in case it helps.
See less See more
goto ati catalyst control center and change the scaling option.
Hello,
Can you please tell me how to do that? And what should I change it to or do?
thanks
See less See more
1 - 6 of 6 Posts
